Incremental encoder and analog input synchronization
Accepted by CUA
Hi CUA,
why don't you follow my recommendations?
Don't use "1Chan 1Sample" mode…
And why do you hesitate to clean up your VI?
Message 11 of 13
(1,878 Views)
Hi GwerdW,
thank you for your advice. Finaly, I get all samples as I supposed. My fault was based on assumption that index of array control shows number of items when scroll bar is at end position. When I used Array Size, I realised that I'm getting all samples as I need.
So thank you again.
Now I am thinking about posibility of reading of time base ticks between each encoder pulse. Should I begin with new post ?
Regards, CUA
Message 12 of 13
(1,792 Views)
Hi. can you please attach your VI here . It will be a huge help. tq
Message 13 of 13
(1,223 Views)
