Index array between limits
Hi All,
I have a byte array which i want to extract some information.
I need to extract 60 cells from the array, so using the index function to form a sub array is not pretty (wiring in 60 constants). Is there another way to do this ? i.e. inex between limits ?
Richard.
(6,315 Views)
Do you want to extract any intermediate values or values from index 2 to 10 ?
(6,311 Views)
I have 74 bytes in my array, and i wish to extract bytes 11 through to 71. Hope what I am asking makes sense,
RIchard
(6,305 Views)
Hello!
This is extremely easy using Array Subset function 🙂
Marcin
Think Dataflow - blog.mtapp.tech
(6,296 Views)
Accepted by lvrichard
You can use array subset, where you need to feed starting index and Length you needArray subset.png
(6,291 Views)
Thankyou PalanivelT and Twardak,
Just what i needed!
Thanks again,
Richard
(6,277 Views)
