Index for loop with boolean array
Hi All,
Nice easy one (I'm sure). How would i make this work ? (I am using a USB 6008).
See attached.
Richard.
(4,107 Views)
You should share your VI, and not a screenshot. We have no idea what you want to do with that Express VI. I have also a feeling that you do not understand the importance of timing (how much you want to wait between iterations of the FOR loop, etc.).
Attach your VI, and explain what is your actual goal?
(4,089 Views)
-Understand first what is for loop, auto indexing functionality.
-Then if you hover mouse over the error wire is will give the hint why it is broken.
Here you go for learning LabVIEW first:
NI Learning Center
NI Getting Started
LabVEW Basics
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
LabVIEW Graphical Programming Course
Using the Context Help Window
LabVIEW Inbuilt Examples
uday
(4,071 Views)
As mentioned above it is hard to say anything without seeing the DAQ Assistant configuration, but the the screenshot gives some hints.
Assuming that the DAQ Assistant is configured to output a line, inserting a "Build Array" block might help:
(4,047 Views)
