Index in Word report
When creating a MS Word report with the Report Generation Toolkit, is it possible to insert an index (table of contents) and divide the document in chapters?
(2,588 Views)
Hi Snamprogetti,
You can follow these steps:
Building a Microsoft Word Template and Adding Content to Bookmarks Using Report Generation Toolkit
Then, if you want to edit chapters in your word document, I'm figuring out that you have to manually set your model by passing text according your ideas.
Let me know if it helps.
Best regards
Matteo
(2,565 Views)
Thanks, but it talks about adding contents to pre-designed bookmarks. I need to create bookmarks at runtime, they can vary depending on data.
I think the only way is using ActiveX properties/methods at low level; references can be obtained with "Word Get ActiveX References".
(2,557 Views)
