Indexing controls on front panel
I have a lot of controls on my front panel.
Is it possible to reference them programmatically with an index instead of connecting wires to every front panel control?
Matteo
(2,427 Views)
Accepted by topic author Matteo_Orciari
I think you can use the "Get and Set Control value" invoke node methods for achieving this. See the image below.
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved:smileywink:
(2,421 Views)
Thanks, this looks like what I wanted to do ... I'll give it a try as soon as I can.
(2,412 Views)
