multi array to single array
Hi all,
I would like to convert 4 separate arrays containing a DBL number into a single array of U8.
Array1     Array2    Array3    Array4                  Output Array (in binary)
1                 1            1              0                             1110
0                 1            0              0                             0100
1                 0            1              1                             1011
1                 0            1              0                             1010
Can anyone help?
(2,542 Views)
Try this..
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved:smileywink:
(2,540 Views)
