Inference with Tensorflow model with GPU
Hello everyone!
Im currently trying to develop a system capable of tracking something with a camera using LabView and a ML model. As the examples within LabView use either Tensorflow or OpenVino and the system I use to train (DeepLabCut) can return a tensorflow model (an older version at least) Im using that. The thing is, I was wondering if the inference blocks (like IMAQ DL Model Run or something else) are capable of using a GPU, either adding something, or editing something.
Id appreciate any information, and if someone has already done a similar project, Id appreciate all your input and experience if possible.
If information about any of this is old knowledge, I apologise, as Im quite new in working with LabView.
Greetings to everyone and thank you in advance!
(734 Views)
I can't tell you if this supports your desired workflow but you should probably look at it and talk with Natan at least once.
https://g2cpu.com/
Rolf Kalbermatter  My Blog
(689 Views)
