Rename References of front panel elements. Is there a bug?
today I met that I'm able to rename the references of controls and indicators while the name of the element itself would not change. This does not make sense in my opinion as the visible relationship between the element and the reference gets lost completely. On the other hand, when I change the name of the element in the block diagram, the name of the reference will change, but only as long as the name of the reference and the element are the same. So I like to aks if this has any useful aspect or if it is a bug?
Original:
Name of the element changed:
Name of reference changed:
Name of control changed after the name of reference and element are not equal:
The internal connection of the elements still remains, but is is a mess for debugging for sure.
Regards, Patrick
_________________________
using LV 2025 Q3
Message 1 of 9
(254 Views)
Hi MECSO,
This is not a "new feature", this behaviour is shown in LabVIEW since ages.
(In older LabVIEW versions I experienced crashes, when I accidentally renamed a reference/property node…)
You should take this conclusion: NEVER rename references/property nodes…
Message 2 of 9
(242 Views)
That's an old and known behaviour. I don't know if it's a bug or not, but if they don't match and you upgrade LV version it can relink and that's definately a bug ... If i'd theorize i'd say "Let users rename refs if they e.g. want to call them 'Test 1 ref' on the block diagram for readability."
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 9
(190 Views)
Personally, I would prefer if references would look more like local/global variables, just with a different glyph (and maybe different text background color). Now the name is naturally locked as it should be.
quick and ugly draft
Nobody really understands the deep meaning of the current "digital" text as used for any numeric scalar reference. Aren't computer all digital? Similarly, we get "string" for strings and "path" for paths. but we can glean that same fact from the color alone!
For arrays, we get "array", independent of the element type (duh!). Here the name of the control would be much more informative!
(Yes labels should be short and concise. We can use the legend for more descriptive text on the front panel if needed)
(Note that local variables can show a label, but it is locked to the name of the VI and while we can (seemingly) change it in the properties dialog (LV2020 as tested), it reverts to the VI name instantly. Sisyphean!)
Message 5 of 9
(163 Views)
I'm assuming you have an Idea Exchange for it? (Yes, that's how it should work/look)
Qestit Systems
Message 6 of 9
(125 Views)
Ok, thanks for you comments. Definitely, there are a lot better solutions than the actual one.
using LV 2025 Q3
Message 7 of 9
(99 Views)
No idea yet. With the semi-broken forum search it is difficult to first check for possible duplicates. 🙂
Message 8 of 9
(75 Views)
It's pretty much the VI Server class name of the frontpanel control. But I agree that the ability to rename the reference control in the diagram and by that loose the only visual connection to the actual control object is not ideal. Your proposal would make a lot of sense and I think would take a programmer in the LabVIEW team not that much time to do. Leave the label available to label it whatever the user wishes, but show the connection to the control in a similar way as for the local variable.
It irked me enough in the past to waste a few thoughts on it, but not enough to go to the hassle of writing an Idea Exchange post.
Rolf Kalbermatter  My Blog
Message 9 of 9
(59 Views)
