Infinite datalogging using cRIO
Hi Igni,
did you read the help for this function?
Why do you wire a local path to the "remote path" input and the path on your HOST PC to the "local path" input??? Homer says "Doh"!
When you don't know how a function works you should ALWAYS read the help for that function and play with example VIs, when available…
Message 11 of 12
(779 Views)
Gerd,
Sorry to disturb you again. I tried wiring local(RT) path to local path and Host(PC) path to remote path.  Still I am getting Error 15550 FTP Transactions : could not open file. I had attached the snippet for better understanding.
I know you will be tensed by my repeated silly question.
But pls help me.
X. Ignatius
Message 12 of 12
(763 Views)
