Info on the OPC server VIs
Where can I find information on the OPC Server and Server Borwser VIs that come with the LabVIEW DSC module? These VIs are located in the C:\Program Files\National Instruments\LabVIEW 6.1\vi.lib\lvdsc\Srvrlibs\_servBrowser and C:\Program Files\National Instruments\LabVIEW 6.1\vi.lib\lvdsc\Srvrlibs\Opc directories. There is no documentation with them!
Maureen
(2,908 Views)
Hi Maureen,
The VIs located in the "..\OPC" directory are used in some way internally by LabVIEW, DSC, or some component such as Server Explorer, and their functionality is not supported. For the VIs located in the "..\\Srvlibs\_servBrowser", you might refer to viserver.pdf located in C:\Program Files\National Instruments\LabVIEW 6.1\manuals.
Remzi A.
(2,908 Views)
Thanks Remzi!
(2,908 Views)
