Initialising combobox within an array cluster
So I have created an array of clusters.
within the cluster are 2 comboboxes which I would like to initialise with a string array I have generated from 'plot_IO'. However I have no clue how proceed further to do that.
Would anybody be able to advise on how it, if it is at all possible.
Thanks.
(4,252 Views)
Hi sherzaad,
use the reference of the array to get a reference to its cluster element. Use that cluster reference to get the reference of the cluster elements. Search the combobox references among them and set their properties…
Or right-click the combobox on the FP and create a reference or property node.
(Keep in mind: in an array all elements share the same properties!)
(4,245 Views)
Thank you GerdW for your reply.
sorry but still a newbie here... and still lost... Would you be able to elaborate more  - maybe with an example Smiley Wink - how to make use of these reference (are referring to creating a reference variable?)
I want all the array elements to be initialised with the same values so your solution should work for me (once I understand it! Smiley Happy)
(4,222 Views)
Accepted by sherzaad
Find the control within the array on the front panel.  Right-click the border of the combo box and select "Create ► Property Node ► Strings []".
Drop that on your block diagram somewhere.  Right-click it and select "Change to Write".  Then wire in an array of your strings for the drop-down.Set combo box strings.png
(4,216 Views)
If you attach your VI, then we can make a few (small) modifications to it and re-post it to show you how to do this.  Please help us by attaching your code, saving us a lot of steps (and ensuring that we can use the appropriate version of LabVIEW that you need).
(4,212 Views)
Worked brilliantly. Thanks and Kudos! Smiley Happy
(4,196 Views)
