Initialization Routine Failed
The error message is attached below.
We are attempting to open a VI from Labview 7.1 in Labview 9. We downloaded the Traditional DAQ 7.4.4 and installed it.
We still get the below error after uninstalling and reinstalling the DAQ.
Next potential step: Revert back to Labview 8 in order to use this VI.
Any advice?
(3,691 Views)
may be worth looking in the conversion thread. Theres a link at the top of the labview posts.if you cant find it heres the link. its the dedicated board for converting between labview versions
conversion board
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,687 Views)
Thank you for the link, however I have a question about it.
The VI in question has a fair number of files, (llb) and (dll) that it is supposed to access, and a number of other executables (that it is currently having trouble running).
Would I need to post all of these for conversion, or would I just post the primary VI, and the conversion process will take care of the rest?
I'm not sure how the process works, so I thought it would be good to ask.
(3,677 Views)
I have been informed that upconverting will not help. The problem persists.
(3,648 Views)
Accepted by topic author ResearchStudentM
Solved. Stepping up from 7.1 to 8.0 to 9.0 worked.
(3,643 Views)
