Installer build spec loses spec for exe to run after
I don't know why, but now & then the build spec for my application installer loses the setting in the Advanced tab to run a certain .exe after installing. The .exe to run after installing is created by a build spec in the same project (from LV source). Besides rebuilding that .exe (without changing the .exe's build spec, name, or location, just minor source code mods), nothing has changed in the project, but the installer's Advanced setting will suddenly be gone. What the heck?!
My project & source files are too large to attach.
(2,492 Views)
Hi Meg,
I noticed this forum post and figured I would chime in here as well.
We have been working on this issue and are hoping to isolate the exact steps that cause the sporadic loss of the postbuild EXE setting. An initial suspicion was the EXE being moved or rebuilt to a different location. That being said, if anyone has run into this issue in the past and has any insight it would be appreciated, as this problem has not been consistently reproduced.
Matt
NI Community Team
(2,446 Views)
