Initialize indicators before show the front panel
I use a vi with UI  (Window appearance = Dialog) where the value of the indicators is passed at calling.
When the VI starts, the UI appears with the last values for some 1/10 s before the inidactors are written correct with tha passed values.
How can I force labview to initialize the inidcators before show them?
(1,062 Views)
Accepted by MichaelBaumgartner80
Hi Michael,
You can simply disable auto Open/Close of the front panel and do it yourself with method nodes:
The example VIs attached are for LV 2020.
(1,049 Views)
