Initializing VI Elements to Default Values
Hi All,
I know how to set values as default on the front panel.  However, when I run a VI multiple times without closing it, I need to re-initialize certain front panel values from their value at the end of the last run to the default values used in the next run.  Generally speaking, I do this using an "Init" state in a state machine or a first frame of a stacked sequence.  In either case, I just create a bunch of local variables and set the values to zero, or whatever other initial value they need.
When I was recently in Core 1 and Core 2 training, the teacher showed us a way to reset all these values without using local variables as described above.  But, for the life of me, I cannot remember what he said to do.
Any help jogging my rapidly-aging memory would be much appreciated.
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(17,211 Views)
Accepted by diarmaede
Invoke Node on the VI to Reinit values to default.
(17,200 Views)
Just to highlight a point. The node RavensFan presented resets ALL controls and indicators to their default values.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(17,180 Views)
Thank you, gentlemen!
Forbes Black
(17,167 Views)
Additional info: if you want to reinitialize only specific controls/indicator, then you can create the corresponding invoke node for that control/indicator (right-click on control/indicator and select Create -> Invoke Node -> Reinitialize to Default).
(17,158 Views)
A good reference for this problem can be found in the NI knowledge section:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MoZSAU&l=en-GB
(8,915 Views)
