Input and Output State
I have a doubt about LABview when I stop the program the I/O state still same before I click on stop program run , example I'm controling a servo motor and if I stop the program the servo still spinning , I just want how can reset the I/O status when I press to end the DAQ programm
Message 1 of 13
(2,281 Views)
Hi Chris, you will have to share your code for specific suggestions. You can set the state of your DAQ card to whatever you need it to be (example set some outputs to 0 V) as your program is shutting down.
Make sure you are not using the abort button (stop sign next to run button) because that is only for emergencies. Your VI should complete its run gracefully e.g. when its task is finished, when a front panel control is pushed, or other stop event is triggered.
Message 2 of 13
(2,277 Views)
Just to clarify, LabVIEW is a graphical programming language; the code you implement using LabVIEW, called "Application," is the one that interacts with your hardware. So, in essence, it would be more appropriate to ask how to achieve a proper shutdown on application close.
Your program must implement a method to properly power down or stop your external hardware, or else it will be like crashing a car into a tree to stop it; of course, there is the best way, to apply brakes, and again, not in the middle of the highway.
Santhosh
Soliton Technologies
Message 3 of 13
(2,236 Views)
This is my code , when I click to abort execution or program occur an error the state of I/O ports still same so the motor keep running
Message 4 of 13
(2,209 Views)
Hi Chris,
  1. I don't see any "abort execution" button, I just see a "Stop" button. How do you "abort execution"?
  2. I don't see any error handling in your VI: how do you react on "occuring errors"?
  3. I don't see any code to gracefully shutdown your hardware system: where do you plan to place this code? (As has been suggested before!)
Message 5 of 13
(2,207 Views)
Screenshot 2024-01-11 111201.png I mean this button near pause , and how  can I make my outputs restart when occur error or press this button?
Message 6 of 13
(2,185 Views)
Do NOT use that button.  It is only meant as a last-ditch option when things go totally wrong.  It is commonly compared to using a tree to stop your car.  You cannot do any clean up when you abort the VI.  Everything just instantly stops where it was.  This is catastrophic when dealing with hardware.
You need to use your actual stop button on your front panel to gracefully let the loop stop, then set your outputs to "off", and then stopping the DAQmx tasks.
Message 7 of 13
(2,179 Views)
I assumed you would do that and provided the example of hitting a tree to stop a car instead of properly pulling over and applying brakes.
You seem to have a Stop button, use it to stop the program and add a logic such that when the Stop button in True, set the value to Servo to stop it.
Santhosh
Message 8 of 13
(2,176 Views)
Already have a logic with panel stop button , but if the code get an error to abort VI ,how can I avoid keep the servo ON?
Message 9 of 13
(2,153 Views)
Hi Chris,
As has been said: do all the cleanup stuff after the loop has finished.
THINK DATAFLOW!
Message 10 of 13
(2,131 Views)
