Inputs (buttons) on USB interface board /event case
I see what you mean, but now it measures the time how long it takes to complete the for-loop. But I need the time how long it takes to come up till 3,14322 volt. That time is 1 tau, and I need it to measure the capacity of the capacitor.
Message 21 of 26
(1,017 Views)
Hi Matt,
the principle of taking time measure is always the same:
- get start time
- do work
- get end time and take difference
All that is put into 3 frames of a sequence. I'm sure you're able to apply that scheme for the parts inside the FOR loop on your own...
Still I suspect the main part of "execution time" is hidden in the "Wait for next multiple".
Also you have to remember: Windows will give you a big jitter on time measurements!
Next point:
You don't have any relation/data dependency between AnalogOutput and AnalogInput. When you want to measure some reaction on your AnalogOutput signal you clearly have a race condition in your code...
One more point:
Putting a (graph) indicator into your tightly timed measurement loop is contraproductive: Updating the graph may take much more time (due to CPU requirements) than doing all those measurements alone...
Message 22 of 26
(1,003 Views)
Hi Gerd,
I tryed it, and put it in 3 frames of a sequence, like your screenshot but it did not work. The time measured was the time of the For loop executing, so that is 6 seconds. And that is also the reason why I have the "Wait for next multiple" is in the for loop, so the 600 iterations take 6 seconds.
I don't exactly know what you mean with the analog output and input... I have changed my VI, I will sent it as attachment..
Maybe it's not all correct, but it is working the way I want.. Accept for the time calculation.. What do you suggest about the Graph? Put it out of the loop?
Thanks anyway for your answer, I can use all support haha...
Message 23 of 26
(995 Views)
This is how it looks (front panel) when working.
Message 24 of 26
(991 Views)
Hi Matt,
see comments in block diagram...
Message 25 of 26
(981 Views)
Thanks a lot GerdW! I did it slightly different, but it's working now! We continue till the next problem occurs Smiley LOL
If you're curious how I did it, see attachment.
Matt
Message 26 of 26
(977 Views)
