Insert 2D data to tree control (recursion) create net topology
Hi all,
I have 2D data array that include parent and children.(i dont have order level!!!).but i know the parent (Pa:00001) is the root.
i want to create a tree control so we can see the connection between the unit.i try to do that but no succsess...any help will be welcom.
pls see the att files.(the jpg file is what i want to achieve).
regard's
eyal.
using labview 2012.win 7.
(3,720 Views)
Hi JTAG
This example can help you build the tree control you want!
Regards
Chris S.
(3,602 Views)
hi ,
thanks for your replay.
my problem is how to order the 2d array.
Pa:00001=root.
                child Ma:01218,                                  Ma:01024
                               Ma:01112,Ma:01130                 Ma:01016,Ma:01074
and ect....
tanks.
(3,560 Views)
This is one way of doing it. Basically start from the parent and for each parent add its children to a queue. Then go over all of them until the queue is empty. There's some cleanup to do, but it shows the basic concept.
___________________
Try to take over the world!
(3,541 Views)
Accepted by JTAG
Hi tst,
wow....wow....wow
excellent job.!!!! thank's.
(3,515 Views)
