Insert all images in a folder into an excel worksheet
I was wondering if its possible to insert all the images inside 2 folders into an excel worksheet, int 2 columns with the name of the picture besides the picture?
Any help will be greatly appreciated.
Thanks!
(3,368 Views)
Accepted by Nando88
Here is the basic principle to get you started.  Calculating the location of the pictures and the text based on the size of the previous picture may be a bit tedious.  MS Word would probably be a bit easier.
aputman
(3,335 Views)
I highly recommend that you add the Error Lines to the functions in aputman's code.  Otherwise, using the Report Generation Toolkit is certainly the way to go ...
(3,311 Views)
