Insert text into a matrix with numberic values
I have a matrix that I'm writting numberic decimal values to but I would like to know if there is a way I can also write text to the same matrix. Currently I have a 10 x 6 maxtrix that contains numberic values (data) but I would like to add a text column to the matrix. I'm using the matrix to display data.
(3,329 Views)
Instead can't you use 2 D array to display 10 x 6 data?. If yes, you can convert the numeric array to string array and you can also add text along with it
(3,324 Views)
Attached is the VI I'm working on. The "Random Number" will be replaced with analog voltage measurements. I would like to add another column to the matrix but this will be a user entered text.
(3,304 Views)
I think I can use a 2D array... I will try this.
(3,303 Views)
Accepted by topic author ashifulk
If you reaaly need a matrix datatype for the mathematics you will be doing, it might make more sense to have a separate string array for the row headers.  I used the Classic style Simple String for the array elements. Of course your wuold hide the string array label and Index Display.
Also, simply create a 2-D array of numerics by autoindexing and then use the Array to Matrix primitive outside the loops.  This will be much more efficient than using Insert into Array and a local variable.
Lynn
(3,284 Views)
Thank you, that will work.
(3,256 Views)
