USB6353 and daqmx?
Hey everybody.
I'm trying to get a generate a sine wave from my NI USB6353 and throw it into a ADC and output a graph of it using LabVIEW and the USB6353. I'm stuck on what to do. Do I use the DAQ Assisstant? Any help appreciated!
(2,550 Views)
@butterwaffle wrote:
Hey everybody.
Attatched is a waveform generator example.  Run the VI then in the Channel control select a virtual channel on the device.  If one isn't there you can choose Create New to make one.  Then select the settings that the output should have (square wave, sine wave, amplitude, offset, frequency, etc) then click start.  This should then generate a waveform that you specified and then put it on the DAQ hardware to be sent to an Analog Out.
(2,501 Views)
