Inserting ActiveX Objects
Did you find the solution for your problem? Did you get to see mgpiezo control option in activeX control
Message 11 of 15
(1,063 Views)
Interested. I just ran across this issue too. Windows 10 OS, Labview 2017 64-bit, APT 32-Bit Software for 64-Bit Windows as instructed by Thorlabs.
Message 12 of 15
(1,040 Views)
If you are experiencing this same issue, I would suggest making a new thread instead of posting on this older one.  That should get more people to see the issue.
Niki Budgell | Product Planner - SW Management | NI
Message 13 of 15
(1,026 Views)
See vi with control with mg17 inserted, check if it finds library.
Message 14 of 15
(1,021 Views)
I've resolved my issue. I was using Labview 2018 64-bit. I loaded LabVIEW 2018 32-bit and all is well.
Mike
Message 15 of 15
(1,013 Views)
