Install Laview 7.0 on Windows XP Home
I tried to install Labview 7.0 on a Windows XP Home system and an error on the Kernell.DLL occured. The same thing happened when I tried with Lookout 5.1.
Any Idea what my problem is?
I did a print screen of the error
Please Note, that I'm using the french version of Windows XP
Tx
(3,357 Views)
Hi Averna,
I have had many strange things happen with LV7 & Win-XP Pro. Believe it or not, re-installing Win-XP cured the problem.
I do not know why you are getting the Kernell.dll error. You may want to re-install (update - I think) your Win-XP installation. Hopefully it will cure it as well. You won't have to re-install LV.
-JLV-
(3,356 Views)
It *might* help if you are logged on as an Administrator
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,356 Views)
I always log on as administrator...
And always buy the "Pro" version of the OS.
XP is my last purchase of MS products... That's it next time I switch to Linux / Unix...
(3,310 Views)
Fortunately, I have not had any problems with either XP Pro or XP home, and for LabVIEW there should be little difference.
Have a look at the comparison matrix.
You absolutely need XP Pro if you have multiple processors. The rest of the additional features are mostly geared for a corporate environment to work better with centralized management and support. None of these are really useful in a standalone environment. I am using both, but I have never encountered any limitation on the "XP home" machine during use.
If you want the "remote desktop" feature, install VNC. 😉
(3,291 Views)
Hi Altenbach,
I guess in due time everbody encounters a problem with something.,...
With me it's definitely XP (and one automobile maker 😠 )
As for LV or any other NI product (as I stated earlier), I have never seen any problem.
I spoke with several people, most did have problems when going to SP2.
However, they were successful on the 2nd try... After reformating the drive... 😠
A friend suggested creating a "Slip-stream" installation CD which includes SP2..
I am unhappy with XP, so I'd better stick with 2000.. It does everything I need and I have no complaints about this one (at least one browny point for Uncle Gates).
XP Home & Pro should basically be the same, especially to run LV7.
Cheers to NI for good products... 😄
hey!! where did that tomatoe come from?????
(3,285 Views)
