sample and function "time"?
Hello sorry for my poor english but there's no forum about Labview in french...
i've 2 questions:
- i import a matrix from a .txt file and i want to calculate the mean and standard deviation but labview take only a sample to calculate and not the whole population... how can i have the mean and standard deviation of the whole pop??
- is there a function to return the exact time in which labview do the calcul? (as tic-toc in matlab)??
it 's for my studies and i need to do a benchmark.... so i need to know in how many time labview can calculate a mean of a 250x32000 matrix.
i hope you've understand what i wanted to say...
thank you!
(3,478 Views)
Hello fabfab1,
here it comes...
To get the time of a subvi/function/whatever you have to make a sequence and get timer value before and after the operation.
To get the mean of a 2D-array you have to convert this array to a 1D for usage of the "Mean/StdDev" function (analyze->math->probability).
Hope this helps,
(3,471 Views)
Try this code.
Randall Pursley
(3,468 Views)
Hello fabfab1,
just a comment:
Keep in mind you're working on very big data structures: 250*32000=8000000 entries - double precision needs 8 byte per entry - giving you a 64 million byte data chunk! It's probably better to split up your data into smaller chunks to avoid heavy usage of a swap file...
And using LabView7.1 on an AthlonXP 2200+ my example takes about 0.75 seconds.
(3,463 Views)
Also...
Forum for LabVIEW in French:
http://forums.ni.com/ni/board?board.id=4170
You can get there by changing the "Select a Community" drop-down box in the upper right-hand corner of the page to "French." It looks like the French-language community is really getting a lot of traffic, too!
--John
(3,457 Views)
That's ok!! Thank you for all!! your files were exactly what i wanted!
(3,448 Views)
