Install fail based on OS detected
Under Additional Installers - set to Automatic.
Under Advanced
- Run exe at end has a command line for running the exe after installation and never been an issue.
- Install custom error code files is TRUE.
- System Requirements set to Windows 7 SP1 or later which I believe is the minimum available.
Message 11 of 11
(252 Views)
