Showing results forĀ
Search instead forĀ
Did you mean:Ā
Installation Problem
I created an Installer on  my computer. Then tried to install the same on same computer. I am getting the error message as attached. Can you please address this problem? Why does it come? What do I do to fix this problem? After this I am not able to run any LabVIEW executable application / LabVIEW on my sytem, I get the same error message.
The details of my system are:
LabVIEWW: 7.1
NI Switch:3.0
NI DMM:2.6
LabVIEW FPGA:1.1
NI RIO: 1.3
Report Generation: 1.1
OS: WindowsXP SP2
Thanx.
Message 1 of 8
(4,593 Views)
I think you ve the problem due to the presence of the LabVIEW Run-Time Engine 7.1.1 in your system.
Uninstall it thro' the Start -->> Settings -->>Control Panel -->> Add or Remove Programs -->> National Instruments Software, Click Remove & Select NI LabVIEW Run-Time Engine 7.1.1 path...
This should eliminate this error problem. It may ve got installed due to the fact that some of the latest drivers automatically install the later version of the Run-Time Engine in our system.
We also encountered with the same problem when creating the installer for an application built in LV 7.1.
Update your feedback here...
- Partha ( CLD until Oct 2027 šŸ™‚ )
Message 3 of 8
(4,580 Views)
One more thing... Please check n confirm yourself whether LV RTE 7.1 is also present in the system before removing LV RTE 7.1.1.
LV RTE 7.1.1 might ve got installed if you ve MAX 4.0 or higher (or even a little bit higher versions of 3, but I m NOT 100% sure).
In most of the cases, LV RTE 7.1 will  also be present, so simply removing the LV RTE 7.1.1 will suffice.
Please DO update your feedback here...
Message 4 of 8
(4,575 Views)
Also, see this link.
http://digital.ni.com/public.nsf/allkb/680e61a4d02158a186256f7a0073c228
Message 5 of 8
(4,573 Views)
Thanks for all the replies!
I tried uninstalling runtime engine 7.1.1, but I get pop up that following products shall be affected due to this uninstall....this includes the RIO1.3, DMM etc, ehich I want to work with, and can't remove. If I say continue on that window.....the uninstallation of RIO, DMM starts. What is the solution for this?
Message 6 of 8
(4,531 Views)
It's all a matter of installing things in the right order. If 7.1 is installed first, drivers needing 7.1.1 components can install on top of it with no problem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 8
(4,524 Views)
YES, it ll start the uninstallation of all the stuff related to 7.1.1...
What you ve to do is let them get uninstalled first & again do carry the reinstallation. Now try to custom install & without 7.1.1. This should solve the problem. If custom installation choice is not avaliable, you re left with no choice other than keeping a seperate system for developing & testing the S/W where your H/W is connected, and another with LV 7.1 & LV RTE 7.1 only for building the exe along with the installer.
Contact the local NI support for more issues.
Message 8 of 8
(4,421 Views)
