A possible 'work around':
Search and locate a program SUBST.EXE (You will find more that one instance)
From the search window select the instance in system32
right click and select "Open Containing Folder"
This should take you in
\Windows dirctry\system32\subst.exe
Right click on this and 'Send' a shortcut to your desktop.
Close the search etc windows and from your desktop
right click on the newlly created shortacut and
select properties.
Edit the target line (that should show something similar to this):
L:\WINNT\system32\subst.exe
so that it becomes:
L:\WINNT\system32\subst.exe C: L:\
and save the changes (Apply or OK)
After you run this shortcut you should see an L: and
a C: drive letters.
Since after LV insta
ll it will look for C: references,
you can copy (or move) this shotcut into a startup directory:
L:\Documents and Settings\\Start Menu\Programs\Startup
or:
L:\Documents and Settings\All Users\Start Menu\Programs\Startup
