can an executable program be run on a machine without labview
how?
(2,997 Views)
Yes. To build an executable program from your LabVIEW VIs to run on a different computer you need to have the LabVIEW application builder. This tool is included in the LabVIEW Professional Development System or can be purchased separately.
Christian L
NI Consulting Services
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(2,997 Views)
As Christian said, you need the Application Builder to build the VI into an executable. All that is required from there is the LabVIEW Run-Time Engine which must be installed on the computer running the application. This is a free download. You must use the version of the Run-Time Engine that matches the version of LabVIEW that was used to develop the application.
Hope this helps. Please let us know if you have further questions.
Kristi H
(2,997 Views)
