Installation problems with NI-Sync 3.0 and LabVIEW 8.6
Forgot to add, I'm running Windows XP Pro SP3, mostly up to date with patches and hotfixes, and have seen this behavior on two different computers.
Message 21 of 27
(1,564 Views)
Thanks for the information Mark,
It looks like the setup is looking for some files that aren't present. Can you verify that SupportFiles\WindowsInstaller-KB893803-v2-x86.exe actually exists in the location you unzipped the beta driver.
I have already checked and this should be bundled along with it. If the file is not present then we can try redownloading the software if that's possible.
Let me know
Can Wong
Message 22 of 27
(1,547 Views)
Can,
I downloaded the beta again and rather than installing it from a network drive copied it to a temporary folder on a local drive, making sure all original folder structures were retained. The installation worked, so the issue of what particular version of Windows Installer was present appears to have been a red herring.
Mark
Message 23 of 27
(1,537 Views)
Can W wrote:
Hello Everyone,
National Instruments is working on releasing a version of the NI-Sync that supports LabVIEW 8.6. In doing this we are also trying to add more features that have been suggested in the Product Suggestion Center. We know that it has been a while since a new version of NI-Sync has been released and for this we are offering the beta version 3.1. You can find a link to this here:  http://zone.ni.com/devzone/cda/tut/p/id/8340
This should also include details on the features that we are adding and the progress being made. We appreciate any feedback you have for us on this.
Thank You
We received our quarterly maintenance DVD shipment for NIDeveloper Suite.
We have all been waiting for this, but we are all nowdisappointed again.
No NI-SYNC that will install on the current version of LabVIEW.
You know, 2004 was a really good year for NI-SYNC; we hadversions 1.0, 1.1, and 1.2 in rapid succession.
In 2005 we got 2.0.
In 2006 we got 2.0.1.
In 2007 we got 3.0.
No updates in 2008.
No updates in 2009.
I don't know what the difference between 2.0 and 2.0.1 was, butI bet you that it fixed something.
Now NI, pay attention, lets do it again.  Lets make a new 3.0.1 version ofNI-SYNC that fixes something.  Whynot let that fix be that new version of NI-SYNC will actually install on to thelatest version of LabVIEW?
Come on NI.  Do something.  It is just a targetdirectory change for goodness sake.
It’s been 2 years since the last update.
Again, I hope we all do not have to wait for LabVIEW 9.2.1and NI-SYNC 4.1.1
before we can again have a version of ni-sync that works withLabVIEW.
Kevin.
Message 24 of 27
(1,450 Views)
Hey Kevin,
The NI-Sync Beta page linked earlier says "At this time, we plan to provide fully supported release candidate versions of these features in late 2009," so that's when you can probably expect the new NI-Sync driver to be released. Participating in the Beta program helps us quite a bit, and any feedback you provide from the Beta program will be extremely helpful for our developers. As Can said, our developers are trying to add more features that have been suggested in the Product Suggestion Center, so if you haven't already done this then I would highly suggest you file a Product Suggestion so our developers can try and address these concerns/suggestions in future releases.
Justin E
National Instruments R&D
Message 25 of 27
(1,432 Views)
Justin, with no due respect intended, I have heard it all before.
Jack Arnold, Systems Engineer - Sound and Vibration, also promised me an updated NI-SYNC by the end of the year.  Jack promise was on 8/20/2008.  I thought he was referring to the year 2008.  You seem to be suggesting it will be in 2009.  I don't know what to believe.  2010 Maybe?
Jack Arnold emailed on 8/20/2008:
Kevin -
The serial number issue will be fixed in a release of NI-SYNC by the end of the year.  Do you need this to be resolved sooner?  If so, would you be willing to use beta software (i.e. not released and not fully tested)?
Jack Arnold
Message 26 of 27
(1,395 Views)
JUST RELEASED.
NI-Sync 3.1 - Real-Time OS, Windows Vista x64/Vista x86/XP
http://joule.ni.com/nidu/cds/view/p/id/1367/lang/en
Message 27 of 27
(1,292 Views)
