Installation troubleshooting?
When installing Labview 7.1 to a fresh XP installation the install progresses to the end of Part 1 of 13 and then prompts to "Please insert the disk: Labview Full Development System".  However this disk (LV_71_FDS) is already in the drive?  I'm sure this is simple but has anyone else seen this? Any ideas?
Message 1 of 10
(4,636 Views)
Could it be that your CD is scratched or otherwise damaged?
Message 2 of 10
(4,630 Views)
There a couple of barely visible scratches but nothing heavy as the disk is only a few weeks old...
Message 3 of 10
(4,626 Views)
Hi DTA,
Try copying the entire to your hard drive and installing LabVIEW from there.  Sometimes this can help any issues with reading from the CD during installation.
Robert Mortensen
Software Engineer
Message 4 of 10
(4,612 Views)
I've had no luck with installing from the HD either...
Message 5 of 10
(4,606 Views)
Did you disable your antivirus?
Message 6 of 10
(4,602 Views)
Antivirus is not installed yet.  The setup is a fresh install of XP
Message 7 of 10
(4,595 Views)
DTA,
Have you tried the CD in a different computer?  If it doesn't work there either, then it may just be a bad CD.  If so, contact your sales representative to get a new copy.
Robert Mortensen
Software Engineer
Message 8 of 10
(4,585 Views)
I have since tested the CD successfully in another computer... I will try and install using another CD drive to see if it is the problem.  I've attached screen capture at the "problem" point.
Thank you all for your suggestions!
Message 9 of 10
(4,578 Views)
Hello DTA,
I have the same problem your... and also my computer has recently installed the operating system (winxp). Any ideas?
Message 10 of 10
(4,003 Views)
