Installed 8.6.1f1 Patch - now LabVIEW has 'no license available'
I've just installed the 8.6.1f1 Patch - and now LabVIEW refuses to start.  I had a look in the license manager and the correct key is in there, but when I try to run LabVIEW it's listed as 'no license available'
Senior Software Development Engineer
Certified LabVIEW Architect and LabVIEW Champion
https://theLonelyAnt.com
https://GDevConANZ.org.au
(3,347 Views)
This will occur when the 30 day trial period has already been used.  If you look in NI License Manager  it shows the License File Expiration.  This will either state the date it expires or 30 days from first use
Message Edited by muks on 09-14-2009 05:11 PM
(3,309 Views)
Accepted by topic author Brett_Percy
Thanks for the reply Muks,
I installed the patch on top of a copy of 8.6.1 that I've been using for many months, it's was definitely registered correctly before the patch.  According to the license manager it was still registered with no expiry date!
Anyway, I've since repaired my installation and it's now working again.  I don't know if the patch correctly installed now though; it seems unlikely
Brett
(3,287 Views)
