Installed LV 8.6 - now NO version of LV will startup!
I had 8.5.1 and 8.2.1 installed and playing nicely together on my Dell Core 2 DUO XP machine.
I then installed LabVIEW 8.6 and a host of other software updates includes on the DVD's.
Installation stopped working at the registration phase.
Now I can not start any version of LV.  I also tried running the license manager, it does not work....
PLEASE don't tell me I have to do this 6 hour install over again....
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 1 of 21
(4,437 Views)
Measurement and Automation Explorer seems to be the only thing I can open and run.  Well the DataFinder starts up fine evidently when I reboot my machine...
MAX can see the installed software and the versions fine.
The error report content shows that I am getting error code 0xc0000005 - which is Access Violation
Message 2 of 21
(4,434 Views)
It sound very much like you have a corrupted installation. Have you tried uninstalling 8.6 to see if you can get 8.5.1 and 8.2.1 working again? You may very well need to perform a reinstall. Make sure you turn off your anti-virus when you do it. If you're connected to the internet you may want to disconnect so you don't get any little beasties sneaking in while it's off.
Message Edited by smercurio_fc on 01-23-2009 12:08 PM
Message 3 of 21
(4,425 Views)
I am trying Repair Installation under Add or Remove Programs first....
just got off the phone with NI - unfortunately will probably have to uninstall and then reinstall.
Message 4 of 21
(4,421 Views)
Ryan,
Before you uninstall anything, check to see how many .lic files are in this folder:
<National Instruments>\ Shared\Licencse Manager\Licences
I have heard of this sort of thing when a large number of files are in this folder, so it is worth checking before you reinstall all of your NI software.
Chris M
Message 5 of 21
(4,416 Views)
Ok well what is the breakpoint on the number of files in this folder?
There are QUITE a few....
102 files
Message Edited by RVallieu on 01-23-2009 12:22 PM
Message 6 of 21
(4,408 Views)
Accepted by RVallieu
Ryan,
I believe the cutoff is 99, so I would bet this is the cause of your issue.  The workaround is to move any unused license files out of the 'Licenses' folder.  You can download a utility that will manage this here:
http://digital.ni.com/public.nsf/allkb/E8725893B2DC948D86257496006F1A99
Chris M
Message 7 of 21
(4,397 Views)
Awesome.  If this works I owe you a beer or two!
Shame the pictures are not working in that page.  This is exactly what is happening - I installed a large number of products from the 8.6 installation DVD.
I will try and report back and mark you answer with Solution if it works.
Message 8 of 21
(4,393 Views)
If you are running Vista,  Go and activate the hidden admin account and try running it there, and also turn off user controls.  I had a similar problem with a dell a while back and that fixed it.
Message 9 of 21
(4,392 Views)
The site is not allowing me to download the LicenseMigrationUtility.exe
Message 10 of 21
(4,388 Views)
