Installer 7.1
I want to create an installer for an application I have built and there are two capabilities that I cannot find. I am using Labview 7.1 and the application builder.
1. I would like to put in a license agreement which will be brought up on the screen with "I agree" and "I do not agree" buttons when the purchaser runs Setup.
2. After the installation I would like to put a shortcut to the installed application on the desktop.
Can I do these two things in Labview 7.1 or should I think of using a general install script program like Wyse or Installshield.
(2,509 Views)
Hello David,
You can do both of these things extremely easily in LabVIEW 8, but the functionality is not built into LabVIEW 7 so you’ll have to be a little creative.  The LabVIEW installer gives an option to run an executable after the installer is run.  From here you can create an executable which will force a user to accept a license agreement, and install a shortcut on the user’s desktop.  One of the reasons that the new features were added to LabVIEW 8 was because customers had been requesting it, so I know users have done this before in LabVIEW 7.
Hopefully this helps get you started, please let us and the community know if you have any other questions!
Travis M
LabVIEW R&D
(2,490 Views)
