Installer Problems in labview8
Hi, all
I have created the installer with the LV8 application builder successfully, but I encountered several problems when running the installer to install this program to other computers.
At the beginning of the install process, the first Error emerged: The NI Unistaller installation has failed. continue? . I pressed "continue" button to keep this install process going on.
and then, at the end of the install process, the second Error occured: The NI math Kernal Libraries installation has failed. continue?. I selected to continue this process, and finally, it show the installation is successful and require to restart the computer.
In program directory, i found my application and double click on the icon, the program works well.
why these two errors happened? and how can I do to fix these problems?
Pls help me~!
(2,889 Views)
Could anybody  have a look at my problems and give me some clues to fix these immediate problems?
Thanks~!
(2,867 Views)
