math script sqrt exe hang
In LAbView 8.0 the sqrt command in the mathscript is not working proper when I try to make a executable. The exe is hanging after I let run it once trough mathscript. When I let run it as vi everything is ok. Is there a patch to clear this problem?
(3,273 Views)
Also the command strcmp hangs the executable up. Seems to be a great implementation.
(3,267 Views)
Building executables containing MathScript functionality is not possible in LabVIEW 8.0.  LabVIEW R&D is working on including this ability in a future LabVIEW version.
-D
(3,263 Views)
i'm using a lot of other commands and there and don't have any problems withe the executable.
(3,255 Views)
