Installer build and USB carrier 9162
I've built an installer from my VI and the deployment PC can't find the driver for the USB carrier 9162 when I hook up the device. Does anyone know which box I have to check to include the device's driver when I build my Installation?
I certainly don't want to include everything that I possibly could just to make it work.
Thanks for the help.
(2,479 Views)
You should just include the driver DAQmx for the C series module that is plugged into the USB sleeve.  When you are building an installer, under the advanced installers section you should include the DAQmx driver.  This will make sure that the driver gets installed on the test machine as well.  Could you tell us what C series module you have in the sleeve and what DAQmx driver you have installed.  Does the sleeve with the module work fine on the development machine?
Raajit L
(2,455 Views)
