Installing LINX error code 8
Hi there,
I am trying to download the LINX package through the VIPM but keep getting an error message saying unable to install with error code 8. Here is the full error message:
Main Package Name: NI LabVIEW LINX Toolkit v1.0.0.9
Package Name with Error: NI LabVIEW LINX Toolkit v1.0.0.9
Error Message: VIPM could not install the package ni_labview_linx_toolkit-1.0.0.9 .
Error Code: 8
Error Source: Delete in 9EDBBD2B992503F5E1BEE944BF726A57->E80C6C79E2825D14672C8F35C1DCFFBB->F7C4E276637B8E633B6AFDD1EF2CE94A->OGPM Class.lvlib:9379CFD8CA331CF0E38A98FA9D7316C6->OGPM Class.lvlib:D5B6EB965D0BC09274E3E5144188318D->C816626B524CF3DD3AA4372A60C7FF8E->VIPM Main Window.vi<APPEND>
C:\Program Files (x86)\National Instruments\LabVIEW 2020\resource\Framework\Providers\LINX_lvrealtime.mxx. File Path: "C:\Program Files (x86)\National Instruments\LabVIEW 2020\resource\Framework\Providers\LINX_lvrealtime.mxx".
The solution I found on another forum was to run everything as an administrator so I changed the compatibility settings on my NI programmes but this did not fix the issue.
What else am I missing here?
Message 1 of 8
(4,750 Views)
@LP_glasgow wrote:
Hi there,
Error Code: 8
#1 Why are you trying install such an old version.  Isn't LINX up to version 3 or something like that?
#2 If this is LabVIEW Community Edition, why are you trying to install it at all?  (It's included.)
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(4,718 Views)
1. this is the version that comes up on the VIPM which is an NI package, unless you are talking about the digilent one?
2. I do not have the community edition
Message 3 of 8
(4,698 Views)
What version of LabVIEW are yo using?
Tim
GHSP
Message 4 of 8
(4,687 Views)
Labview 2020 (full edition)
Message 5 of 8
(4,682 Views)
Interesting.  I see that standalone LINX has been updated to be compatible with LV 2020.  What "bit-ness" is your LV?  32?  64?  LINX will only work on 32-bit LV.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(4,677 Views)
I'm using 32 bit!
Message 7 of 8
(4,531 Views)
@LP_glasgow wrote:
I'm using 32 bit!
Sorry to disappoint you, but I am responding to say only that I have read your response.  I don't have an answer for you, unfortunately.  😞
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(4,526 Views)
