Installing LabVIEW DSC 8.6 Run Time on Windows XP Embedded flash memory
I'm trying to install LabVIEW DSC 8.6 Run Time on an embedded PC running Windows XP Embedded. This has a small local disk (c), so I would like to install DSC Run Time on a secondary flash memory drive (d). The installer tells me that I don't have enough free space on drive c, but I cannot browse to select drive d. What do I need to do to get this installed?
Josh
(3,153 Views)
The DSC module can't easily be installed to external flash memory. You'll want to move any extra data onto the flash drive to free up space on the internal memory for installing the DSC module.
Mark E.
(3,097 Views)
