Mass Flow Meter
Hi all,
I am using PCI 1710 board to control fuel cells vlaves and Mass Flow Meter.
Could any one help in getting the mass flow meter show me the Flow rate of the Gas.
I am using Burkert 8006 Mass flow meter and I wanna connect the MFM to the PCI 1710 and jus want to show me the flow rate. Could any one tell me, to which pin should i connect the MFM to, it has a 15 Pin Sub HD Socket. (Currently taking output from the Process Value Output and Process value ground and connected to the PCI1710 A11 and A10(Analog)). Thank. Awaiting your response.
Vijay
Message 1 of 14
(5,667 Views)
Vijay,
When you purchased the MFM it should have had a pin out that tells you what each pin is for. I have a few MFM from other companies and they always proivded this information. If you do not have that Information you should be able to get it from the manufacturers web site or talk to the support people from that company. If this is not what you are asking then I am not sure what your question is.
Also I would reccomend attaching your device as a differential signal. It looks like you have it set up RSE. Differential is less likely to have noise.
Tim
GHSP
Message 2 of 14
(5,652 Views)
I pulled the sepc sheet for this device. What communication protocal did you get (rs-232)? If you did get the RS-232 model then you will have to do serial communication to the device. There are good example on how to do this in the Example that NI prvides whit LabVIEW.
Tim
GHSP
Message 3 of 14
(5,650 Views)
Do you have this document?
Tim
GHSP
Message 4 of 14
(5,649 Views)
Message 5 of 14
(5,636 Views)
Thanks a lot aeastet for the reply.
I had went thro this document. Currently I am not using RS232 for my communication purpose as i am not controlling my MFM rather I am using A11 of PCI1710(of the extension board) for my application apperently my MFM doest have RS 232 port, it just has the 15 Pole sub HD port.
Currently i am using the Process Value Ouput and Process Value Ground and connected to the A11 and A11 Gnd(Not sure if tats correct). I chose just because my ajenda is jus to get the get the flow rate. Please suggest me an appropritae method to interact with the PCI1710 board to have the flow rate using LABVIEW.
Thanks again
Message 6 of 14
(5,622 Views)
What connections do you have to this device? According to the manual you should have a 9 pin D sub connector for the 8006 model. If you have a 15 pin D sub I will try the 15 Pin D sub connections that are in the book on page 7.
If this does not work I am not sure what to tell you. It should use RS-232 with these connections. Did you get a MFM that has communication protocols?
Tim
GHSP
Message 7 of 14
(5,615 Views)
So do u mean to say, i can connect the TXD and the gnd to the A11 and A11 gnd of the PCI 1710?
Message 8 of 14
(5,609 Views)
I would try it and see if you can see the communication. If not I am not sure how you would go about it. Looking at this manual it looks like this model should have had a 9 pin connector. Since it has a 15 pin connector I would guess that the 15 pin connector applies. Call the tech support for this company and see what they have to say about it if connecting to pin 11 and ground do not get you what you are looking for. I still believe that you are going to have to send and recieve to the what you are looking for. You will have to ask the device for the data and it will send it to you.
Tim
GHSP
Message 9 of 14
(5,604 Views)
We don need to connect the RXD to the board??? i wonder the MFM provides continous transmission with an request!!!!
Message 10 of 14
(5,601 Views)
