Dear Pcs07,
Thanks for posting. I could reproduce the error.
I think, you must include the c-file, which generate the the function DEMLP_Load.
This is the function, which you call in the call function library node.
Refer to the following link.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=CBF49DC95BF46BD9E034080020E74861&p_node=DZ52000&p_source=external
Please ta look in the example application, and furthermore take a look in the link, which I have post some entries before (using exernal code with LV PDA).
You include the file in the menubar:
1. Tools
2. Build for PDA...
3. Change to Source Files
4. Add here the c-file
Save and try to build the application again.
That should fix the problem.
Hope that helps,
best regards.
SebastianN
NI Germnay
