Installing a program witout user interaction
Hi
Is it possible to build a installation that runs in the background, means no interaction from the PC user?
The senario is, we got at lot of test PCs at different locations and it would be nice if we could push at new version of a program to the PCs and doing it in the background so the operator don't notice it.
regards Bjarne
Message 1 of 11
(4,087 Views)
do you want to make a Run-Time installation, or an exe replacement ?
Best Regards,
V-F
Message 2 of 11
(4,084 Views)
I don't have an exact answer, but you can start here:
https://decibel.ni.com/content/docs/DOC-2955
Lots of links at the bottom of that page that might assist, also.
http://www.medicollector.com
Message 3 of 11
(4,063 Views)
Thank you Smiley Very Happy
I have made a program with the AppBuilder(LV2012) and want a silent installation.
The link was helpfull (if I use LV6) but it need an update to include LV2012Smiley Frustrated
I have posted a comment for that.
Regards Bjarne
Message 4 of 11
(4,040 Views)
Did you try this link off the original page referenced:
http://digital.ni.com/public.nsf/allkb/DE2BAD19D4A9124C862573B400808EC6?OpenDocument
It seems to be current.
Message 5 of 11
(4,031 Views)
Hi
Yes I did and I tried it too, but as far as I understand it only works for LV/NI installations. Not the one you make your self.
/Bjarne
Message 6 of 11
(4,007 Views)
I don't have a LV 2012 installation with which to confirm, but it install my 2011 installation package with no issues.  Other than the Windows 7 UAC prompt, it installed with no interaction from me.  This is with a installation package created by me.
Message 7 of 11
(3,981 Views)
I have tried it again and it seems that something i happening(mouse timeglass is rolling), but it does not install the program:-(
Message 8 of 11
(3,967 Views)
You can try using the /log switch to generate a log file and see what is going on during installation.  I am assuming this installation works non-silently, correct?
Message 9 of 11
(3,957 Views)
Sorry for the late reply.
It is working nowSmiley Very Happy
If an old version of the program on the PC, then the first run uninstall the old program.
Then I have to run the command again to install the new version!
How do I avoid to run the installation twice?
thanks in advance
Bjarne
Message 10 of 11
(3,898 Views)
