Installing the run-time engine as a non-administrator
I want to distribute a stand-alone application to end-users that are not administrator of their computer.  When they try to install the RTE without administrator privileges, the installer cannot continue because it cannot write to the C:\ base directory.  How can I fix the run-time engine installer to work without administrator privileges?
(2,578 Views)
As far as I know it is not possible
(2,556 Views)
On the second screen of the installer, the user can choose an alternative target location. Have you tried that?
(sorry, I don't know how well this will work). What is the runtime version?
(For your reference, this document describes planned changes in the folder structure for future LabVIEW versions.)
(2,531 Views)
