got code?
Before I build a new VI from scratch, does anyone already have one that formats and writes the standard error cluster to file?
Zach
(3,213 Views)
Hi zach,
which file format do you need?
[edit] you can also use the build in xml functions. [/edit]
Mike
Message Edited by MikeS81 on 08-19-2008 08:49 PM
(3,210 Views)
Hi Mike,
Any format is acceptable as long as the contents are easily viewed.   My main priority is to capture the error cluster in file for later reference...
Zach
(3,204 Views)
Accepted by topic author super-neuron
Hi Zach,
i have no ready function, but what about this solutions?
Hope it helps.
Mike
(3,190 Views)
That will work great... Thanks!
(3,179 Views)
