Instrument I/O Assistant with PXIe-1062Q
I'm using a PXIe-1062Q with LabVIEW 2009 installed on it. In the Measurement & Automation Explorer the chassis is visible, as well as the two PXIe-6363 cards I built in. Even th self test of the 6363 works without any failures.
My Problem is, that after if I insert an Instrument I/O Assistant 1.01 in LabVIEW, and click on Select an instrument, the two PXIe-6363 don't appear in the list. Only Com1 and LTP1 is listed.
What shall I do? Thank you very much for your support!
Kind regards, Michael
(2,805 Views)
Accepted by Michael Cerny
The 6363 is programmed with DAQmx functions. You would use the DAQ Assistant.
(2,784 Views)
Thanks Dennis, after a DAQ Driver update it worked.
(2,779 Views)
