Instrument I/O Assistant
I'm having some trouble with the Instrument I/O assistant.
I have an instrument hooked up to the serial port via RS232 null-modem cable.
I can read in information, and then parse the individual tokens.......once.
If I try to put this I/O assitant in a loop, or run it more than once, I get an error:
Error 1 occurred at Scan From String (arg 1) in Instance           8 12Gas Analyzer .vi->Gas Analyzer.vi
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
Any thoughts?
- Cory
Cory K
(2,836 Views)
Will there be data to be read?
Can you post your code?  that would be easier...
R
(2,825 Views)
