Problems (bugs) with Project Explorer LV8.5.1 Windows Vista 64bit
Helo all,
I am using Windows Vista 64bit with all updates and service packs on an ASUS G1 dual core 4gig memory.  After writing code for a while I find that I cannot execute my top level vi from the project explorer.  I can run the vi from outside the project no problem.  If I try to create a new project and load the vi into it the LV hangs and the windows task manager cannot kill either the vi or the new project explorer, I have to reboot the computer to recover.  I have attached the vi.
regards,
Karl
(2,619 Views)
Hi Karl,
I am having a look at this issue--I shall try to reproduce it and get back to you with my results.
Ipshita C.
(2,589 Views)
