03-12-2010 04:39 PM
Jeff Bohrer wrote:
From the Spy file I can't see the Termination char on send? Do you have the wrong setting? the Sorenrsons need the term char to work RELIABLY although they usually understand the commands anyway the command parser does get confused on occasion.
How is the LF appended to the write message? Do I add a \n or 0x0A to the write buffer?
03-12-2010 05:18 PM
03-13-2010 08:41 AM
03-13-2010 11:19 AM
sounds like a solution!
Hmmmm It MUST be timing! (the extra overhead of the USB-GPIB adaptor)
Not all equipment MFGs expected the PC to ever break the "200MHz Barrier" ![]()
