Instrument only works with NI Spy running.
Jeff Bohrer wrote:
From the Spy file I can't see the Termination char on send?  Do you have the wrong setting? the Sorenrsons need the term char to work RELIABLY although they usually understand the commands anyway the command parser does get confused on occasion.
How is the LF appended to the write message? Do I add a \n or 0x0A to the write buffer?
Message 11 of 14
(884 Views)
OK, went to MAX and set EOS to 10. Also set send eoi with eos. I tried a lot of combinations of termination. Also told it I had many meters of cable. Nothing helps. I need to put the *WAI in next. But that will have to wait as this is a deployment system w/o debug.
Message 12 of 14
(879 Views)
Got a NI USB GPIB adapter this a.m. and tried it out. It doesn't care about the termination settings, it works regardless.
Message 13 of 14
(864 Views)
sounds like a solution!
Hmmmm It MUST be timing!  (the extra overhead of the USB-GPIB adaptor)
Not all equipment MFGs expected the PC to ever break the "200MHz Barrier" Smiley Very Happy
Message 14 of 14
(857 Views)
