Instrument problems with compiled VIs
I have two Vi's that communicate with two different instruments via GPIB, both are Rhode and Schwarz. One is a power meter and the other a spectrum analyzer.
When the vi is uncompiled and run there are no problems. When I compile these into an .exe application and try to run them I get time out errors on both instruments.
I'm using Labview 5.1.1 to compile these and run on the same PC. I am using the serial ports during each vi but I don't think that its the problem.
I'm at a lose and would appreciate any assistance.
(2,837 Views)
Have you remembered to include a '.ini' file alongside the '.exe'? For example if your application is fred.exe then you need a fred.ini to go with it. In addition, within the '.ini' you need a line that begins 'serialDevices='. Compare this with labview.ini in your labview directory.
Hope this helps
Regards
Keith Fuller
(2,837 Views)
