make current values default
Hello ng,
Can anyone tell me how to programatically make
the current values of all controls on a panel the
default values?
Furthermore, can I set all controls back to their
default state programatically?
Thanks!
Charlie Solomon
Raytheon Systems Co.
charliesolomon@yahoo.com
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 11
(7,859 Views)
In article <7qk261$53i$1@nnrp1.deja.com>, wrote:
>Hello ng,
>default values?
To make them the default values individually, you can right click on the
number, go to "Data Operations," then hit "Make current value default."
I can't tell you how to do all of them at the same time, if that is what
you mean.
To make them go back to default, same thing, right click the number, go to
"Data Operations," then "Reinitialize to Default."
Hope that helps,
Harry
"Little Joe for the Big Heisman, '99"
Message 2 of 11
(7,859 Views)
That's a good question. I almsost positive there's not a direct way to
prgramatically get them back to default values.
Two ideas:
For every control you want to set back to a default value, make a copy
of it on your front panel, and set the default value. Now, when you
want your control to go back to default, set it via a local variable
("Copy of Control A" -> 'Write' local of Control A). If you have a lot
of controls, you can control them with a cluster. Just make sure you
never overwrite the Copy of the control.
Or, this idea is weird, but might work well in your situation... since
default values are only assigned if there is no other input, you could
make the variable you want to reset and put it in a sub-VI which
consists of one input and one output wired toget
her. In that sub VI,
set the default value of the control. Now, on your outer VI, if you
ever want to assign it its default value, wire up the sub VI with a
'Write' local of the control.
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
Message 3 of 11
(7,853 Views)
Thanks Rick,
That would work for resetting controls to the same default values every
time...I should explain my app better: I have a subvi that pops up
a "setup" panel, allows the user to change some controls, then gives
the option to Save or Cancel. Save button should make the current
panel values the new default, so that next time the app is closed and
reopened these new values will be in place. Cancel button will undo
the changes and reset the controls back to the default state.
Only thing I could find in the Help was some reference to
a "Make_Current_Values_Default" DLL, but no info on how to find it or
access it. Thanks,
Charlie
Message 4 of 11
(7,853 Views)
Are we talking about LabVIEW 5 here? If so check out the VI Server
functionality.
In the Functions palatte under Application Control you can open a VI
reference to
a VI with Open VI Reference and then using the Invoke Node you have both
"Make Current Values Default" as well as "Reinitialize All to Default
available".
These functions match exactly the same commands in the Operate menu.
charliesolomon@my-deja.com wrote in article
<7qkdgv$di6$1@nnrp1.deja.com>...
> Thank
s Rick,
> access it.
Rolf Kalbermatter  My Blog
Message 6 of 11
(7,853 Views)
Invoke Node was exactly what I needed...however, "Make current values
default" is not working. I get an error msg saying "current state is
not compatible with this command." I've tried using the Set State
method to unlock or lock the VI with no luck. Any ideas? Thanks,
Charlie
ps - Reinitialize to defaults works great!
> functionality.
> reference to
both
> available".
> These functions ma
Message 7 of 11
(7,843 Views)
You can't make current values default for a running or active VI. This
means
you can't do this from inside the VI but rather need to do it form another
VI
and before or after you executed that VI. The VI may alslso not be a subVI
of
another running VI as it is then also running or at least in a prepared for
running
state.
Also you will need to save the VI afterwards if the default values need to
remain
over a restart. You can save a VI with Invoke Node, too but the save
operation
does not work in a standalone application (created with the application
builder.)
charliesolomon@yahoo.com wrote in article <7qq2k9$g2i$1@nnrp1.deja.com>...
> Charlie
Message 8 of 11
(7,842 Views)
As you can see, the Invoke Node has some limitations in this case,
especially with built apps. Another way of doing what you want is to save
the current default values to a file, and load them in at the start of VI
execution. If the user changes values and hits 'Save' write out the new
values to the file. If they hit 'cancel', do nothing (keep the current
values in the file). There are limitations to this approach as well, but I
find it works best for me in most situations, especially if I'm going to
build an executable. I think both approaches are valid and have there
place. You have to decide what will work best for you in your situation.
Good Luck!
Scott Menjoulet
Message 9 of 11
(7,833 Views)
charliesolomon@my-deja.com writes:
> Hello ng,
> default values?
Charlie,
Do you know about the feature in LV 5 to read and write .ini files ?
Looks like a very clean solution to me.
Johannes Niess
Message 5 of 11
(7,848 Views)
All you have to do to make all your current values default values, is to set up an application reference to the current VI and then wire this to an invoke node. One of the methods is 'Set Current Values to Default'. I believe that you can use this same methode to reinitialize values to the default state.
Message 10 of 11
(7,832 Views)
